2006 Toyota Tacoma Signal Lights Replacement
  1. 2006 Toyota Tacoma Signal Lights Replacement, Signal Lights: step 1, image 1 of 2 2006 Toyota Tacoma Signal Lights Replacement, Signal Lights: step 1, image 2 of 2
    • Turn on the car, and switch the signal light ignition, so that both lights turn on.
  2. 2006 Toyota Tacoma Signal Lights Replacement: step 2, image 1 of 3 2006 Toyota Tacoma Signal Lights Replacement: step 2, image 2 of 3 2006 Toyota Tacoma Signal Lights Replacement: step 2, image 3 of 3
    • Turn on your car, and check the signal lights on the rear end of the car.
    • Identify which side stopped blinking and/or burnt out (left side or right side).
  3. 2006 Toyota Tacoma Signal Lights Replacement: step 3, image 1 of 2 2006 Toyota Tacoma Signal Lights Replacement: step 3, image 2 of 2
    • Find a new replacement signal bulb according to the side where the light needs to be replaced.
    • Use the car model, make and year to find the light that best suits the car.
  4. 2006 Toyota Tacoma Signal Lights Replacement: step 4, image 1 of 1
    • Prepare to remove the old turn signal.
    • Open the hood of the lens.
  5. 2006 Toyota Tacoma Signal Lights Replacement: step 5, image 1 of 2 2006 Toyota Tacoma Signal Lights Replacement: step 5, image 2 of 2
    • If needed, use a screwdriver to remove hood.
  6. 2006 Toyota Tacoma Signal Lights Replacement: step 6, image 1 of 3 2006 Toyota Tacoma Signal Lights Replacement: step 6, image 2 of 3 2006 Toyota Tacoma Signal Lights Replacement: step 6, image 3 of 3
    • Remove the light bulb casing.
  7. 2006 Toyota Tacoma Signal Lights Replacement: step 7, image 1 of 3 2006 Toyota Tacoma Signal Lights Replacement: step 7, image 2 of 3 2006 Toyota Tacoma Signal Lights Replacement: step 7, image 3 of 3
    • If needed, replace the electric connector with a new one, aligning and screwing the replacement in the same place.
    • Push the locking and turn it counterclockwise to unscrew the bulb.
  8. 2006 Toyota Tacoma Signal Lights Replacement: step 8, image 1 of 2 2006 Toyota Tacoma Signal Lights Replacement: step 8, image 2 of 2
    • Replace the bulb with the new one.
    • Insert the new bulb. Align the pins on the bulb with the ones inside of the car.
  9. 2006 Toyota Tacoma Signal Lights Replacement: step 9, image 1 of 3 2006 Toyota Tacoma Signal Lights Replacement: step 9, image 2 of 3 2006 Toyota Tacoma Signal Lights Replacement: step 9, image 3 of 3
    • Place the new bulb back on the designated place.
    • Replace the hood/lens back on the car.
    • Turn the ignition switch on and engage the blinker lever (first step) to ensure proper instalment.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 584
