2006-2013 Toyota Corolla Turn Signal Bulb Replacement
  1. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement, Turn Signal Bulb: step 1, image 1 of 2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement, Turn Signal Bulb: step 1, image 2 of 2
    • Pull the hood release lever towards yourself until the hood pops.
    • Open and move the bonnet lever towards the left to completely release the hood.
  2. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 2, image 1 of 2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 2, image 2 of 2
    • Lift the prop and place it inside bonnet hole to keep the hood open.
    • The hood prop will be located towards the front of the engine.
  3. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 3, image 1 of 2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 3, image 2 of 2
    • Turn your wheel to the appropriate side to locate the signal light.
    • For the left signal light, you would turn your wheel inwards to the right. While for the right side turn your wheel inwards by turning left.
  4. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 4, image 1 of 3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 4, image 2 of 3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 4, image 3 of 3
    • Pry off the clip under the wheel well using a flathead screwdriver.
    • Remove the lining by pulling it straight back.
    • Some cars are different and may need different tools. For example, some have nuts holding the liner so you'll need a wrench.
  5. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 5, image 1 of 1
    • Twist the signal housing counter-clockwise until it releases.
  6. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 6, image 1 of 3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 6, image 2 of 3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 6, image 3 of 3
    • With one hand grab the socket and with the other pull the bulb straight out of the socket.
  7. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 7, image 1 of 3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 7, image 2 of 3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 7, image 3 of 3
    • Insert the new bulb into the empty socket place the signal light back into the housing and twist it clockwise to the original position.
  8. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 8, image 1 of 3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 8, image 2 of 3 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: step 8, image 3 of 3
    • Make sure your signal works properly by turning it on.
Alexander
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 83
All Time: 556
