2006-2013 Toyota Corolla Headlight bulb Replacement
  1. 2006-2013 Toyota Corolla Headlight bulb Replacement, Headlight bulb: step 1, image 1 of 1
    • Locate the handle to open the hood
    • Open the hood of the car.
  2. 2006-2013 Toyota Corolla Headlight bulb Replacement: step 2, image 1 of 1
    • Locate the bulb. It will be in the front and the side. (Start with side opposing the battery).
    • Twist assembly 45 degrees counterclockwise and pull straight out.
  3. 2006-2013 Toyota Corolla Headlight bulb Replacement: step 3, image 1 of 2 2006-2013 Toyota Corolla Headlight bulb Replacement: step 3, image 2 of 2
    • Lift up on the latch and pull. The bulb will come free from the wires
  4. 2006-2013 Toyota Corolla Headlight bulb Replacement: step 4, image 1 of 1
    • Change the light bulb.
    • Put it back in place and twist the assembly the other way around.
  5. 2006-2013 Toyota Corolla Headlight bulb Replacement: step 5, image 1 of 1
    • Use step 3 to 7 for the other side.
After reviewing the guideline you should be more than capable to replace an headlight by yourself.
Attached Documents
Frantz Etienne
151 Reputation
1 Guide authored
One Comment
The driver's side is harder as you have to remove stuff to get to the bulb. And depending on the year it could be a push pin or bolt that holds the stuff in place.
Resist - Reply
Past 24 Hours: 8
Past 7 Days: 85
Past 30 Days: 352
All Time: 7,029
