2005-2007 Ford Freestyle AC Compressor Control Valve Replacement
  1. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Order Control Valve: step 1, image 1 of 1
    • Before getting started, go ahead and order a new AC Compressor Control Valve. eBay is a good option and so is your favorite online auto parts retailer. Search for "Dorman 917-275". About a $40 part. Some local auto parts stores may carry this part as well. Try NAPA.
  2. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Evacuate AC System Refrigerant: step 2, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Evacuate AC System Refrigerant: step 2, image 2 of 2
    • In order to replace the AC Compressor Control Valve safely, the AC system will need to be depressurized. This is best done professionally to ensure the refrigerant is disposed of properly.
    • Any automotive shop offering AC service can do this for half their 1 hour labor rate. In this case, $49 to evacuate the system.
    • Ask the shop performing this procedure to provide you visual verification that your AC system has been completely evacuated. Don't be shy.
  3. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Under Hood Orientation: step 3, image 1 of 1
    • Now that the refrigerant has been removed professionally, it's your turn to go to work. Pop the hood of a 2005-2007 Ford Freestyle, Ford 500, or Mercury Montego and you're looking at a 3.0L V6 DOHC 24V DURATEC engine. This was the one and only engine option for these vehicles.
  4. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Locate and Remove AC Compressor Control Valve Backing Plate: step 4, image 1 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Locate and Remove AC Compressor Control Valve Backing Plate: step 4, image 2 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Locate and Remove AC Compressor Control Valve Backing Plate: step 4, image 3 of 3
    • The AC Compressor Control Valve is located behind a backing plate on the rear of the AC compressor. The AC compressor itself does not need to be removed. A short 10mm box end wrench will get the job done. A ratchet and 10mm socket will help.
    • Since this step occurs adjacent to an exhaust manifold, use appropriate gloves to protect your skin from hot surfaces.
    • Remove plate with bolts. Set these items aside, they will be re-used. This is a good time to clean the plate and retaining bolts. A small amount of WD40 and shop towel will work fine.
  5. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Remove AC Compressor Control Valve, Spring, and Seal: step 5, image 1 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Remove AC Compressor Control Valve, Spring, and Seal: step 5, image 2 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Remove AC Compressor Control Valve, Spring, and Seal: step 5, image 3 of 3
    • Removing the backing plate reveals the AC Compressor Control Valve and seal.
    • Using dexterous fingertips or a dental pick, slowly remove the AC Compressor Control Valve and spring. Use the dental pick to extrude the green rubber seal from its groove without marring the machined surface.
    • The used AC Compressor Control Valve and seal are waste. Keep the spring, it will be re-used.
  6. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Clean Backing Plate Mating Surface: step 6, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Clean Backing Plate Mating Surface: step 6, image 2 of 2
    • A small amount of WD40 on a shop towel will work fine to clean the backing plate mating surface on the AC Compressor.
    • Wipe the surface clean of refrigerant and be careful not to knock any road grime into the AC Compressor Control Valve housing.
  7. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Prepare Parts for Installation: step 7, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Prepare Parts for Installation: step 7, image 2 of 2
    • Use a clean surface to layout everything needed to install the new AC Compressor Control Valve and seal.
    • Spring, backing plate, and bolts shown here are re-used.
    • Attach spring to AC Compressor Control Valve. The spring will simply snap into place with an interference fit.
  8. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Lubricate and Install Seal: step 8, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Lubricate and Install Seal: step 8, image 2 of 2
    • Apply 2 drops of motor oil to the new seal and completely lubricate.
    • Carefully press seal into groove without picking up any debris during the process.
  9. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Lubricate and Install AC Compressor Control Valve and Spring: step 9, image 1 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Lubricate and Install AC Compressor Control Valve and Spring: step 9, image 2 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Lubricate and Install AC Compressor Control Valve and Spring: step 9, image 3 of 3
    • Apply 3 drops of motor oil to the AC Compressor Control Valve mating surface and completely lubricate.
    • The AC Compressor Control Valve and spring assembly will install spring side first.
    • Install the assembly without picking up any debris during the process.
  10. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Install AC Compressor Control Valve Backing Plate: step 10, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Install AC Compressor Control Valve Backing Plate: step 10, image 2 of 2
    • There will be obvious witness marks on the backing plate indicating the install orientation of this part.
    • Install backing plate hand tight.
  11. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Create Access to AC Low Pressure Port: step 11, image 1 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Create Access to AC Low Pressure Port: step 11, image 2 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Create Access to AC Low Pressure Port: step 11, image 3 of 3
    • There is a module attached to the passenger side shock tower. Start by removing the module's wiring harness.
    • Next, use a standard sized flathead screwdriver to depress the clip holding the module to its mounting bracket.
    • Carefully place the module out of the way.
  12. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Locate AC Low Pressure Port: step 12, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Locate AC Low Pressure Port: step 12, image 2 of 2
    • The AC low pressure port is now in plain sight. The port is covered by a black cap.
    • Remove the black cap to reveal the port.
  13. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Prepare Refrigerant and Dispenser: step 13, image 1 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Prepare Refrigerant and Dispenser: step 13, image 2 of 3 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Prepare Refrigerant and Dispenser: step 13, image 3 of 3
    • 2005-2007 Ford Freestyle, Ford 500, and Mercury Montego with "Front AC" (most) use 29 ounces of R-134A refrigerant.
    • For a Front AC application start with 24 ounces or (2) 12 oz. cans of refrigerant. R-134A refrigerant is available at any auto parts store in 12 oz. cans. You will need a separate dispenser like the one shown here by EZ Chill.
    • Avoid "Stop Leak" refrigerant types and stick with untreated R-134A refrigerant.
    • Refrigerant cans are designed to be attached to the dispenser full and removed from the dispenser empty. Proceed to thread the first can of refrigerant onto the dispenser. The dispenser will pierce and seal the can.
    • Do not remove the refrigerant can from the dispenser until the can is completely empty.
  14. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Attach Refrigerant Dispenser to Low Pressure Port: step 14, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Attach Refrigerant Dispenser to Low Pressure Port: step 14, image 2 of 2
    • R-134A AC systems use quick disconnect ports. To attach the dispenser, first compress the coupler.
    • When attaching coupler use a shop or plastic glove to protect your skin should any refrigerant discharge during the process.
    • Next, cover the port squarely with coupler and release. Nest can in a secure spot.
  15. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Start Engine and Run Max AC: step 15, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Start Engine and Run Max AC: step 15, image 2 of 2
    • Start engine and let idle with transmission in park and parking brake engaged.
    • Set AC to coldest setting and turn fan to high.
  16. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Dispense Refrigerant into AC System: step 16, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Dispense Refrigerant into AC System: step 16, image 2 of 2
    • Pull trigger on dispenser while slowly clocking can back and forth until first can is completely empty.
    • Attach second can of refrigerant and dispense until AC system holds steady at 40-45 psi. Detach coupler.
  17. 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Reinstall Cap and Module. Test Drive.: step 17, image 1 of 2 2005-2007 Ford Freestyle AC Compressor Control Valve Replacement, Reinstall Cap and Module. Test Drive.: step 17, image 2 of 2
    • Reinstall low pressure port cap.
    • Reinstall module and reattach harness. You're done with the replacement.
Before making a test drive with your corrected AC System, inspect the AC Compressor Control Valve Backing Plate for any leaks. Give your motor compartment a complete check for any tools or supplies left behind. Close the hood and test drive your vehicle and verify the AC system is performing as new during normal driving conditions.
9 other people completed this guide.
Jon Mikelonis
381 Reputation
1 Guide authored
6 Comments
clar and well illustrated
Bob Reudink - Reply
During The Last Few Steps, Just Before Adding New Refrigerant. You Should have Pulled An Vacuum On the System If You Are Not Going To Replace The Receiver, Drier Unit Or Also Called The Accumulator, Drier Unit, Because That Will Keep The Air And Moister Out Of The A/C System.
Retired Auto A/C Tech, Marcus
Marcus - Reply
is the vacuuming an additional step along with evacuating the system? In other words, before replacing the control valve, I should evacuate as well as vacuum?
Glenn Clark -
GREAT instructions and pics! the only problem I had were my FAT hands!
Douglas Polcuch - Reply
AC compressor control is a focusing process for ac maintenance. Always we have to clean the ac other wise ac occurred many problems. Because recently faced ac overheating problem then contacted the ac repair dubai service center and solve the problem.
Fulter Gixa - Reply
Past 24 Hours: 7
Past 7 Days: 57
Past 30 Days: 170
All Time: 23,951
