2005-2010 Honda Odyssey Headlight Bulb Replacement
  1. 2005-2010 Honda Odyssey Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 1
    • Pull the hood release lever to pop the hood.
  2. 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 2, image 1 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 2, image 2 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 2, image 3 of 3
    • Pull the lever under the hood of the car, right above the Honda logo, to release the hood.
  3. 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 3, image 1 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 3, image 2 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 3, image 3 of 3
    • Lift the hood strut and insert the end of the strut into the corresponding groove.
    • Ensure the hood is supported properly.
  4. 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 4, image 1 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 4, image 2 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 4, image 3 of 3
    • Determinethe headlight that you need to replace on either side of the vehicle.
  5. 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 5, image 1 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 5, image 2 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 5, image 3 of 3
    • Apply pressure on the flap and pull it down.
  6. 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 6, image 1 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 6, image 2 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 6, image 3 of 3
    • Turn the socket counterclockwise to release it from its housing.
    • Pull the bulb directly out of its socket.
  7. 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 7, image 1 of 1
    • Get a replacement bulb.
    • Take care not to touch the bulb with bare skin.
  8. 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 8, image 1 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 8, image 2 of 3 2005-2010 Honda Odyssey Headlight Bulb Replacement: step 8, image 3 of 3
    • Put the bulb in, tighten the bulb, and reconnect the connector.
Now remove the hood mount and close the hood you should hear a loud sound when it is completely closed and it should be flush with the rest of the vehicle
Gursiman
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 47
All Time: 330
