2005-2010 Honda Odyssey Cabin Air Filter Replacement
  1. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Locate the Glovebox: step 1, image 1 of 1
    • Locate the glove box, which is positioned in front of the passenger-side seat.
  2. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Open the Glovebox: step 2, image 1 of 2 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Open the Glovebox: step 2, image 2 of 2
    • Pull on the handle to open the glovebox.
  3. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Dampener Hinge: step 3, image 1 of 3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Dampener Hinge: step 3, image 2 of 3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Dampener Hinge: step 3, image 3 of 3
    • Remove the cover of the dampener on the upper left-hand side (facing the glovebox) by pulling the semi-circular piece towards your body.
    • Pull the actual hinge outward and off of the cylindrical piece to which it was hooked.
  4. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Stops: step 4, image 1 of 3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Stops: step 4, image 2 of 3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Stops: step 4, image 3 of 3
    • The stoppers are snapped in place with plastic at the top left and right side of the glovebox. Use a flathead screw driver to unsnap these hinges from their place.
    • Using one hand, push the glovebox slightly closed to create space. Using the other hand, rotate the piece and pull outward (perpendicular from the wall of the glovebox) until the hinge comes free.
    • Repeat for both stoppers on each side.
  5. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Locate and Remove the Air Filter Holder: step 5, image 1 of 3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Locate and Remove the Air Filter Holder: step 5, image 2 of 3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Locate and Remove the Air Filter Holder: step 5, image 3 of 3
    • Press inward on the two plastic pieces on each side of the air filter and pull towards yourself for removal.
  6. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Take Out the Old Air Filter and Replace: step 6, image 1 of 3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Take Out the Old Air Filter and Replace: step 6, image 2 of 3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Take Out the Old Air Filter and Replace: step 6, image 3 of 3
    • The air filter will be in the removed holder.
    • Remove the old air filter and replace it with the new air filter. There will be an arrow to point in the direction of "air flow". Make sure these arrows match on both the container and the filter.
    • Place the container holding the new air filter back and push until it snaps into place.
    • Use these directions in reverse to rebuild your glovebox.
Andrew Williams
160 Reputation
1 Guide authored
UM-KIM-S21S52G20 Member of UM-KIM-S21S52G20
Community
1 Member
1 Guide authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 131
All Time: 3,247
