2002 Kawasaki KLR650 Carburetor Rebuild
  1. 2002 Kawasaki KLR650 Carburetor Rebuild, 2002 Kawasaki KLR650 Carburetor Rebuild: step 1, image 1 of 2 2002 Kawasaki KLR650 Carburetor Rebuild, 2002 Kawasaki KLR650 Carburetor Rebuild: step 1, image 2 of 2
    • Use an 3 mm Allen wrench to loosen the drain screw on lower portion of bowl.
    • Remove old fuel left inside of bowl.
  2. 2002 Kawasaki KLR650 Carburetor Rebuild: step 2, image 1 of 2 2002 Kawasaki KLR650 Carburetor Rebuild: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the four screws on the outside of the bowl.
    • Remove the bowl from the carburetor and take out the gasket from the bowl.
  3. 2002 Kawasaki KLR650 Carburetor Rebuild: step 3, image 1 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 3, image 2 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 3, image 3 of 3
    • Remove the pilot jet using a flat head screwdriver.
  4. 2002 Kawasaki KLR650 Carburetor Rebuild: step 4, image 1 of 2 2002 Kawasaki KLR650 Carburetor Rebuild: step 4, image 2 of 2
    • Remove the main jet using a flat head screwdriver.
  5. 2002 Kawasaki KLR650 Carburetor Rebuild: step 5, image 1 of 2 2002 Kawasaki KLR650 Carburetor Rebuild: step 5, image 2 of 2
    • Remove the main jet sleeve using an 8 mm combination wrench.
  6. 2002 Kawasaki KLR650 Carburetor Rebuild: step 6, image 1 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 6, image 2 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 6, image 3 of 3
    • Push out the retaining pin holding in the float and float seat.
    • Remove this assembly from the carburetor.
  7. 2002 Kawasaki KLR650 Carburetor Rebuild: step 7, image 1 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 7, image 2 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 7, image 3 of 3
    • Flip the carburetor around and remove the four screws securing the top housing using a Phillips #1 screwdriver.
    • Note that this is spring loaded.
  8. 2002 Kawasaki KLR650 Carburetor Rebuild: step 8, image 1 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 8, image 2 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 8, image 3 of 3
    • Pull up on the diaphragm carefully to remove the diaphragm and slide.
    • Take out the needle and plastic needle retainer.
  9. 2002 Kawasaki KLR650 Carburetor Rebuild: step 9, image 1 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 9, image 2 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 9, image 3 of 3
    • Replace the needle and reassemble the slide.
    • Insert the slide assembly back into the carburetor.
    • The needle needs to be lined up with the hole in the carburetor. Make sure that the diaphragm makes a good seal in the carburetor gasket groove.
    • Insert the spring into the slide assembly and put the plastic housing back on.
    • Maintain pressure while screwing the four Phillips screws in the housing since it is spring loaded.
    • Tighten the screws in a diagonal pattern to ensure that the plastic housing is sealed properly.
  10. 2002 Kawasaki KLR650 Carburetor Rebuild: step 10, image 1 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 10, image 2 of 3 2002 Kawasaki KLR650 Carburetor Rebuild: step 10, image 3 of 3
    • Place the new float seat onto the float.
    • Place the float assembly into the carburetor and slide the retaining pin back into its hole to secure the assembly.
    • Make sure that the float can move freely.
  11. 2002 Kawasaki KLR650 Carburetor Rebuild: step 11, image 1 of 2 2002 Kawasaki KLR650 Carburetor Rebuild: step 11, image 2 of 2
    • Insert the new pilot jet into the carburetor. Tighten it with a flathead screwdriver.
    • Do not over tighten the pilot jet as it is made of brass and may strip easily.
  12. 2002 Kawasaki KLR650 Carburetor Rebuild: step 12, image 1 of 2 2002 Kawasaki KLR650 Carburetor Rebuild: step 12, image 2 of 2
    • Reinsert the main sleeve and tighten with an 8 mm combination wrench.
    • Insert the new main jet into the main jet sleeve. Tighten using a flathead screwdriver.
    • Do not over tighten as this is made out of brass and may strip easily.
  13. 2002 Kawasaki KLR650 Carburetor Rebuild: step 13, image 1 of 2 2002 Kawasaki KLR650 Carburetor Rebuild: step 13, image 2 of 2
    • Insert the new gasket into the bowl gasket groove.
    • Use a Phillips #1 screwdriver to replace the four screws securing the bowl to the carburetor.
    • Tighten in a diagonal pattern to ensure that the bowl is sealed properly.
  14. 2002 Kawasaki KLR650 Carburetor Rebuild: step 14, image 1 of 2 2002 Kawasaki KLR650 Carburetor Rebuild: step 14, image 2 of 2
    • Use a 3 mm Allen wrench to tighten drain screw at the bottom of carburetor.
Shawn Marcoux
253 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 62
All Time: 1,550
