Introduction
If the outer door handle on your 2002-2009 Kia Sorento is broken and in need of replacement then use this guide to replace the broken or defective outer door handle.
Outer door handles are essential for the car door in order to get inside the car unless opened from the inside.
This guide will reacquire you to remove the interior door panel in order to access the outer door handle mechanism. This means that there will be some careful prying and there is a chance that feeble or weathered plastic parts might break.
Step 4 requires you to detach the interior door light's bulb, this was done by simply twisting and detaching the light bulb while it is on. Be careful as the light bulb get hot if it's on for a long period. Use caution and work gloves to protect your hands.
Some of the screws are hidden under plastic screw covers or panels which have to be carefully pried off. Use a spudger or opening tool if possible to remove the screw covers.
Use a Phillips #1 screwdriver to remove the screws behind the covers.
Peel off the upper right corner of the plastic covering to reveal the inside of the outer door handle.
One of the 10 mm hex nuts is revealed immediately (highlighted with the red circle) but the second 10 mm hex nut is behind a plastic tape which must be removed to access it (highlighted by red arrow).
To loosen the nuts use the 10 mm socket and ratchet with an extension.
To reassemble the door follow the step in reverse order.
4 Comments
I am just wondering my daughter has the 2006 Kia Portage 16 valve now her handle broke off but it's not actually the handle it's the metal part that it hooks to what is it called
Sorry it was a Kia Sportage 16 valve and I just don't know what part to order the little metal rod that the handle hooks to snap what part do I need to order to fix it
I was told it was the actuator but when I looked on Amazon I didn't see the plastic housing that it would hook to I'm hoping a mechanic can let me know I am a tradesman myself just not a mechanic and we need some guidance
If it makes it easier I would give you my personal number so we can text personally
