Introduction
Change the coolant in your '99 to '02 SV650. Use pure coolant for superior heat protection, anti-freeze mixtures to help with cold conditions, or diluted coolants or pure water for use on race tracks.
Remove the radiator cap security screw with a Phillips #1 screw driver by turning it counter-clockwise.
Remove the radiator cap by pressing down on it and turning it counter-clockwise until it can be lifted off the radiator.
Locate the 10 mm hex coolant drain plug. It is on the right engine cover, just below the coolant outlet.
Turn the coolant drain plug counter-clockwise with a 10 mm socket wrench or box end wrench until it can be turned freely by hand.
Place a container under the drain plug to catch the coolant when it comes streaming out of the coolant drain hole.
Pour approximately 1.7 quarts of coolant into the radiator, or fill until you can see coolant near the filler neck. Use one hand to stabilize the funnel to prevent spills.
Remove the funnel and place the radiator cap back over the radiator filler hole. Press down on the cap and turn it clockwise until it is snug.
Insert and turn the radiator cap security screw clockwise until it is snug.
Dispose of your old coolant properly by taking it to a shop that accepts coolant or a dump that excepts hazardous waste.
5 other people completed this guide.
One Comment
Thank you! Project went smoothly all though I didn’t have the security screw on my 2001 sv650.
