1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement
  1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Plastic Rain Tray: step 1, image 1 of 1
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 2, image 1 of 1
    • Remove the rubber gasket from the rain tray.
  3. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 3, image 1 of 1
    • Lift the tray upwards and away from the vehicle.
  4. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Front Windshield Wipers: step 4, image 1 of 1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 5, image 1 of 1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  6. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 6, image 1 of 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 6, image 2 of 2
    • Gently lift up the passenger-side windshield wiper.
  7. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 7, image 1 of 1
    • Remove the driver-side windshield wiper in the same fashion.
  8. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: step 8, image 1 of 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: step 8, image 2 of 2
    • Lift up the plastic cover.
  9. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 9, image 1 of 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 9, image 2 of 2
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  10. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 10, image 1 of 1
    • Use a #2 Phillips screwdriver to remove the front two screws.
  11. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 11, image 1 of 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: step 11, image 2 of 2
    • Gently unplug and lift out the automatic transmission control unit.
8 other people completed this guide.
Matthew Newsom
39,530 Reputation
67 Guides authored
5 Comments
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - Reply
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - Reply
got a question if your display light is dim what could be the problem
dean wafula - Reply
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - Reply
thank you very much .
emad_szs - Reply
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 122
All Time: 43,782
