1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement
Video Overview
A video about installing MP3 Player in BMW E39 http://www.youtube.com/watch?v=_6wg3qTvU....
  1. 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement, BMW E38 E39 X5 X3 Z4 E46 MP3 Player: step 1, image 1 of 1
    • Remove screws holding the CD changer in place (if equipped)
    • Disconnect BMW CD changer 3 pin power plug and 6 pin audio plug from CD changer.
    • Connect MP3 Player to original CD changer connectors
  2. 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement: step 2, image 1 of 3 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement: step 2, image 2 of 3 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement: step 2, image 3 of 3
    • If using the 3 and 6 Pin connector version MP3 player, you will need to connect the unit to a switched power source in order to retain its last song played memory function.
    • A good connection for BMWs built after Jan, 2000 production is the SES wiring plug, which is no longer used in cars that are equipped with the BMW Bluetooth system
    • Switched power is located on pin 24 Violet/White (or Violet/Red see image.
    • If you are also installing the DSP adapter module with your MP3 player you can connect the DSP module adapter to this pin in addition to using pin 14 brown/black for ground.
5 other people completed this guide.
Martin Bishop
4,373 Reputation
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 35
All Time: 13,611
