Introduction
The valve cover gasket is normally replaced at the recommendation 100,000 miles tune-up. In some cases, valve cover gasket failure may occur sooner and cause oil leaks which would require a replacement to fix the oil leak. Oil leaks will lead to engine oil starvation and will cause extensive damages to the engine.
All models within the year 1996-2000 Honda Civic have the same valve cover gasket. This guide will illustrate the basics of an oil leak from a bad valve cover gasket and provide instructions on replacing the valve cover gasket.
Pull the lever towards you to release the hood. You should hear a pop release coming from the front of the hood.
Push and hold the hood latch with the left hand and pull the hood up with your right hand to open.
Lock the hood stand into the two holes to keep the hood up located on the right-hand side of the hood.
Install the valve cover back onto the engine.
Install the five 10mm bolts onto the valve cover starting with the middle first follow by the outer bolts in an X-pattern fashion.
Install the single 10mm bolt with the spark plug wire fixture mount.
Install the spark plug wires back into the valve cover in numeric order that it was removed.
Install the air intake breather tube.
Now that you have successfully installed a new valve cover gasket, the oil-burning into the atmosphere is now gone along with improving the engine's life.
