1994-2000 Toyota RAV4 Clock Repair
  1. 1994-2000 Toyota RAV4 Clock Repair, 1994-2000 Toyota RAV4 Clock Repair: step 1, image 1 of 3 1994-2000 Toyota RAV4 Clock Repair, 1994-2000 Toyota RAV4 Clock Repair: step 1, image 2 of 3 1994-2000 Toyota RAV4 Clock Repair, 1994-2000 Toyota RAV4 Clock Repair: step 1, image 3 of 3
    • Use a Phillips #3 screwdriver to remove the 17.0 mm screw at the top of the instrument cluster trim.
    • Remove the instrument cluster trim by pulling it up and out.
  2. 1994-2000 Toyota RAV4 Clock Repair: step 2, image 1 of 2 1994-2000 Toyota RAV4 Clock Repair: step 2, image 2 of 2
    • Use a Phillips #3 screwdriver to remove two 20.0 mm screws holding the dash in place.
  3. 1994-2000 Toyota RAV4 Clock Repair: step 3, image 1 of 3 1994-2000 Toyota RAV4 Clock Repair: step 3, image 2 of 3 1994-2000 Toyota RAV4 Clock Repair: step 3, image 3 of 3
    • Use a Philips #3 screwdriver to remove the two 17.0 mm screws located underneath the radio trim.
    • Gently pull the radio trim off.
  4. 1994-2000 Toyota RAV4 Clock Repair: step 4, image 1 of 3 1994-2000 Toyota RAV4 Clock Repair: step 4, image 2 of 3 1994-2000 Toyota RAV4 Clock Repair: step 4, image 3 of 3
    • Place your fingers behind the three dashboard buttons to remove them slightly.
    • Do not yank or pull on the buttons when removing or unplugging them, this may damage the wire connections.
    • Unplug the dashboard buttons from the connectors.
  5. 1994-2000 Toyota RAV4 Clock Repair: step 5, image 1 of 3 1994-2000 Toyota RAV4 Clock Repair: step 5, image 2 of 3 1994-2000 Toyota RAV4 Clock Repair: step 5, image 3 of 3
    • Remove the four climate control knobs.
  6. 1994-2000 Toyota RAV4 Clock Repair: step 6, image 1 of 2 1994-2000 Toyota RAV4 Clock Repair: step 6, image 2 of 2
    • Pull out the Air Conditioning button.
    • Gently pull off the climate control base plate.
  7. 1994-2000 Toyota RAV4 Clock Repair: step 7, image 1 of 3 1994-2000 Toyota RAV4 Clock Repair: step 7, image 2 of 3 1994-2000 Toyota RAV4 Clock Repair: step 7, image 3 of 3
    • Gently pull the dashboard outwards to gain access to the backside of the clock.
    • Don't attempt to remove the dashboard completely because you will damage the wiring connected to the security alarm.
    • Unplug the connector for the clock.
  8. 1994-2000 Toyota RAV4 Clock Repair: step 8, image 1 of 3 1994-2000 Toyota RAV4 Clock Repair: step 8, image 2 of 3 1994-2000 Toyota RAV4 Clock Repair: step 8, image 3 of 3
    • Use a Philips #3 screwdriver to remove the three 15.0 mm screws that are holding the clock onto the backside of the dashboard.
    • Remove the clock.
  9. 1994-2000 Toyota RAV4 Clock Repair: step 9, image 1 of 3 1994-2000 Toyota RAV4 Clock Repair: step 9, image 2 of 3 1994-2000 Toyota RAV4 Clock Repair: step 9, image 3 of 3
    • Use a spudger and gently pry the tabs on the side of the case of the clock.
    • Remove the top case of the clock.
    • The clock control buttons may fall out when opening the case, be sure to keep them in place for reassembly.
    • Use a Phillips #0 screwdriver to remove two 9 mm screws that secure the circuit board.
  10. 1994-2000 Toyota RAV4 Clock Repair: step 10, image 1 of 3 1994-2000 Toyota RAV4 Clock Repair: step 10, image 2 of 3 1994-2000 Toyota RAV4 Clock Repair: step 10, image 3 of 3
Nigel Andrews
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 70
All Time: 1,126
