Introduction
The Cadillac Northstar V8 is widely known to consume more oil than most engines—as much as a quart every 1,000 miles. Though you may be adding new oil fairly frequently, it's important that you still change your engine oil and filter every 3,000-5,000 miles, depending on your driving conditions.
Cadillac (as well as many automotive experts) strongly discourage the use of any oil additives, even those that claim to decrease oil consumption.
Place a jack underneath the frame near the passenger side front wheel.
Raise the car with the jack until you can work comfortably under the car.
Place a jack stand on the frame immediately behind the jack.
Slowly lower the jack until the car is resting on the jack stand and remove the jack.
Locate the oil drain plug along the side of the oil pan. It is a 14 mm hex bolt that faces towards the driver side of the car.
Place an oil drain pan under the oil drain plug to catch the old oil.
Use a 14 mm box end wrench to loosen the drain plug until you can turn it by hand.
Continue to loosen the drain plug by hand until it comes free and oil begins to drain.
While the oil is draining, wipe off the drain plug with a clean rag or towel.
Remove the old drain plug gasket and replace it with a new one. Be sure that the new gasket fits over the threads of the drain plug.
The oil filter is located right next to the oil pan underneath the car.
Loosen the oil filter by turning it counter-clockwise with your hand or an oil filter wrench.
Once the filter comes off, place it with the open end facing down in the oil drain pan to allow the oil to drain out of it.
Place a funnel into the oil filler hole.
Pour 5 quarts of 5W-30 or 10W-30 oil into the funnel.
Reinstall the oil filler cap and tighten it by turning it clockwise until it is snug.
Allow 12-24 hours for all of the oil to drain out of the old oil filter.
Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge to you. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
6 other people completed this guide.
2 Comments
окна
мне
иееф н€£@ффффпнтнэ
союз щебня о юных но
сяй69щощ
