1993-1997 Toyota Corolla Headlight Bulb Replacement
  1. 1993-1997 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 1
    • Reach underneath the panel below the steering column and pull the black lever to unlock hood. The lever will have an icon of a car with a propped open hood.
  2. 1993-1997 Toyota Corolla Headlight Bulb Replacement: step 2, image 1 of 1
    • Place two fingers underneath hood but directly on top of Toyota emblem to locate hood latch. Push up with both fingers to unlock latch.
  3. 1993-1997 Toyota Corolla Headlight Bulb Replacement: step 3, image 1 of 1
    • Located right behind the headlight is a red Deutsch connector. Push down on that connector to unplug wiring and rotate unconnected portion counterclockwise, facing from the driver's view, to remove bulb.
  4. 1993-1997 Toyota Corolla Headlight Bulb Replacement: step 4, image 1 of 1
    • With bulb exposed, twist broken bulb counterclockwise to unscrew from electrical connection. Screw in new bulb clockwise and replace back into socket.
  5. 1993-1997 Toyota Corolla Headlight Bulb Replacement: step 5, image 1 of 1
    • Be very careful twisting new bulb into electrical connection as the bulbs are very easily damaged.
6 other people completed this guide.
Shane Moore
272 Reputation
1 Guide authored
USF Tampa, Team 1-23, Donnelly Fall 2014 Member of USF Tampa, Team 1-23, Donnelly Fall 2014
USFT-DONNELLY-F14S1G23
1 Member
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 52
All Time: 10,851
