1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement
  1. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement, Manual Driver’s Side Mirror: step 1, image 1 of 3 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement, Manual Driver’s Side Mirror: step 1, image 2 of 3 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement, Manual Driver’s Side Mirror: step 1, image 3 of 3
    • Unscrew the two T25 Screws located on the sides of the mirror.
    • The mirror should be bolted inside (which we will get to later), so the mirror should not fall.
  2. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 2, image 1 of 3 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 2, image 2 of 3 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 2, image 3 of 3
    • Inside the door panel, there are two Philips screws. One in the panel's upper right side, the other inside the door pull. Remove both.
  3. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 3, image 1 of 3 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 3, image 2 of 3 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 3, image 3 of 3
    • Turn the crank handle until the knob is facing upward. Using a hook pick or a small flathead screwdriver, gently pry open the front cover.
    • Rotating the cover out of your way, unscrew the T20 screw from inside the handle.
    • To avoid losing the screw, slide the cover back over the handle without fully removing it. However, make sure not to clamp it closed.
  4. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 4, image 1 of 3 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 4, image 2 of 3 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 4, image 3 of 3
    • Three plastic retaining clips are located at the bottom of the panel. To remove those clips, either use a fastener removal tool or your hands.
    • Release the door panel from the door lock by lifting it up. To clear the door handle, move the door panel to the right.
  5. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 5, image 1 of 2 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 5, image 2 of 2
    • With the panel removed. Locate the 10 mm bolt near the speaker at the top. Using a 10 mm socket, loosen the bolt.
    • Keep one hand on the mirror to prevent it from falling. This will remove the mirror from the truck.
  6. 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 6, image 1 of 2 1992-1996 Ford F-150 Manual Driver’s Side Mirror Replacement: step 6, image 2 of 2
    • To remove the mirror, lift up and to the left to clear the arm inside the door.
Rachelcall
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 149
