1986-1993 Volvo 240 Spark Plug Wires Replacement
  1. 1986-1993 Volvo 240 Spark Plug Wires Replacement, Spark Plug Wires: step 1, image 1 of 1
    • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
  2. 1986-1993 Volvo 240 Spark Plug Wires Replacement: step 2, image 1 of 2 1986-1993 Volvo 240 Spark Plug Wires Replacement: step 2, image 2 of 2
    • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
    • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
Install your new spark plug wires in the same manner that you removed the old ones.
2 other people completed this guide.
David Hodson
150,782 Reputation
127 Guides authored
2 Comments
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - Reply
These directions were great! Thank you. I got the wires on in about 40 minutes. Oh, and I’m a girlie girl. :)
Nancy - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 21
All Time: 4,050
