1986-1993 Volvo 240 Front Brake Caliper Replacement
  1. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: step 1, image 1 of 3 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: step 1, image 2 of 3 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: step 1, image 3 of 3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: step 2, image 1 of 2 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: step 2, image 2 of 2
    • Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
  3. 1986-1993 Volvo 240 Front Brake Caliper Replacement: step 3, image 1 of 2 1986-1993 Volvo 240 Front Brake Caliper Replacement: step 3, image 2 of 2
    • Lift the brake caliper off the rotor and set it aside.
    • Place the caliper on some type of support so that you do not put too much strain on the brake hose.
  4. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: step 4, image 1 of 2 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: step 4, image 2 of 2
    • Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper.
    • Brake fluid will come out of the loosened brake hose. You should keep a bucket or pan nearby to collect it.
    • Be careful when handling brake fluid, as it may strip paint and dissolve some plastics.
    • Detach the brake hose and remove the brake caliper.
    • When you install the new calipers you will need to bleed the brakes to remove any air from the brake fluid lines.
David Hodson
150,782 Reputation
127 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 6,282
