12-String Takamine G Series Guitar String Replacement
  1. 12-String Takamine G Series Guitar String Replacement, Guitar String: step 1, image 1 of 3 12-String Takamine G Series Guitar String Replacement, Guitar String: step 1, image 2 of 3 12-String Takamine G Series Guitar String Replacement, Guitar String: step 1, image 3 of 3
    • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
    • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
  2. 12-String Takamine G Series Guitar String Replacement: step 2, image 1 of 2 12-String Takamine G Series Guitar String Replacement: step 2, image 2 of 2
    • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
  3. 12-String Takamine G Series Guitar String Replacement: step 3, image 1 of 2 12-String Takamine G Series Guitar String Replacement: step 3, image 2 of 2
    • Place the new string into the hole in the bridge where the pin was taken out.
  4. 12-String Takamine G Series Guitar String Replacement: step 4, image 1 of 3 12-String Takamine G Series Guitar String Replacement: step 4, image 2 of 3 12-String Takamine G Series Guitar String Replacement: step 4, image 3 of 3
    • Place the pin back into the hole to secure the string.
  5. 12-String Takamine G Series Guitar String Replacement: step 5, image 1 of 1
    • Grab the string and put it through the hole located on the tuning post of the guitar.
  6. 12-String Takamine G Series Guitar String Replacement: step 6, image 1 of 3 12-String Takamine G Series Guitar String Replacement: step 6, image 2 of 3 12-String Takamine G Series Guitar String Replacement: step 6, image 3 of 3
    • Take the string and wrap it around and underneath itself.
    • Pull the string taught.
    • Twist the string over itself and than cut off the excess string.
  7. 12-String Takamine G Series Guitar String Replacement: step 7, image 1 of 2 12-String Takamine G Series Guitar String Replacement: step 7, image 2 of 2
    • Turn the tuning peg counterclockwise to tighten the string.
Rey Navarro
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 65
