Xbox 360 Xenon Parts
The Xbox 360 Xenon was the first revision of the Xbox 360. Unfortunately, the Red Ring of Death has been a very common problem with this revision of the 360. This revision also lacked the HDMI port found on later Xbox 360 models.
Results
Showing products 1 - 10 of 11
| | Xbox 360 Red Ring of Death Fix KitUsed to fix Xbox 360 consoles with the RROD failure. | $29.95–$49.95 |
| | Xbox 360 Dual Fans (Early Model)Early (Xenon) dual cooling fans with power cable and four-pin connector. | $39.95 |
| | Xbox 360 GPU Heat SinkGPU heat sink with attached mounting posts. Thermal paste not included. | $29.95 |
| | Xbox 360 CPU Heat SinkCNC aluminum CPU heat sink originally equipped on late Xbox 360 consoles. | $19.95 |
| | Xbox 360 RF ModuleSmall Circuit board housing the electronic power button and LED status lights. | $14.95 |
| | Xbox 360 Upper Case Screw SetSet of screws securing the upper case to the chassis. | $9.95 |
| | Xbox 360 Optical Drive Tray Cover & Eject ButtonPlastic optical drive tray cover and eject button. | $9.95 |
| | Arctic Silver Thermal Paste3.5 gram Arctic Silver thermal paste tube | $8.95 |
| | Arctic Silver ArctiCleanTwo part thermal paste remover | $7.95 |
| | Xbox 360 Optical Drive SATA CableShort black SATA cable transferring data between the motherboard and optical drive. | $4.95 |
