Xbox 360 Parts
The Xbox 360 was the successor to Microsoft's Xbox and debuted in 2005.
The Xbox 360 has been plagued by the so-called "Red Ring of Death" (RROD) hardware problem. Fixing your Xbox 360 can be a cost effective alternative to buying a new console. There are five models of the Xbox 360, each identified by a code name. Select your console version above, or use our ID page if you're not sure which model you own.
Results
Showing products 1 - 10 of 10
| | Xbox 360 Red Ring of Death Fix KitUsed to fix Xbox 360 consoles with the RROD failure. | $29.95–$49.95 |
| | Xbox 360 GPU Heat SinkGPU heat sink with attached mounting posts. Thermal paste not included. | $29.95 |
| | Xbox 360 CPU Heat SinkCNC aluminum CPU heat sink originally equipped on late Xbox 360 consoles. | $19.95 |
| | Xbox 360 RF ModuleSmall Circuit board housing the electronic power button and LED status lights. | $14.95 |
| | Xbox 360 Upper Case Screw SetSet of screws securing the upper case to the chassis. | $9.95 |
| | Xbox 360 Optical Drive Tray Cover & Eject ButtonPlastic optical drive tray cover and eject button. | $9.95 |
| | Arctic Silver Thermal Paste3.5 gram Arctic Silver thermal paste tube | $8.95 |
| | Arctic Silver ArctiCleanTwo part thermal paste remover | $7.95 |
| | Xbox 360 Optical Drive SATA CableShort black SATA cable transferring data between the motherboard and optical drive. | $4.95 |
| | Xbox 360 Optical Drive Power CableTen wire power cable connecting the optical drive to the motherboard. | $4.95 |
