iBook G4 14" freezes when graphics are rich
Reply by gsj4gsj
I've got a very nice 14" G4 iBook awhich functions fine, except that it doesn't seem to like sticking at any intense graphics processing. When I first acquired this as a faulty item it would freeze after a few minutes. The Genius Bar at my local Apple Store suggested it was a hardware fault and that a new hard-drive would sort it out. This did seem to solve the problem - up to a point. It trundles along very happily for hours in word-processing or even on long video compression tasks. But run anything graphics rich (like a game) and it'll go for ten minutes max before freezing. Does this sound like anything obvious? I can post further machine spec if anyone has ideas/needs more info.
Many thanks
GSJ
Sounds to me like a heat issue. Do you have a small fan you can run on low and point the airflow across the bottom of the machine as it runs? I'd test that and see if it helps.
Reply reply by QEIIRepair
Your iBook knows when it's getting too hot and it wont let you continue what your doing if it is. Sarabian raises a valid point in the short term. In the long term you should replace your fan and your heat sink: both are available on ifixit.com. This is an odd problem but as iBooks are quite old now, it's important to replace the occasional part to keep the system fresh.
Reply reply by gsj4gsj
Thank you both - I haven't successfully tested a fan-assisted work-out, fans not being essential household items for the British climate. iStat Nano widget tells me that the fan is running at 0rpm though I don't know if that is the norm for G4 iBooks when running normally. The only other piece of info is that the pointer can still be moved via the track-pad after the rest of the screen freezes. And at the last test there was no sign of a temperature spike on iStat. I'll see if I can extend work-time by some form of external cooling, and if that yields results, will go for spare parts option. Many thanks again. GSJ
Reply to: iBook G4 14" freezes when graphics are rich
