Sure. You need to prepare the "target" HD by partitioning first. Split it so that you have at least the same amount of space in one partition as the "source" drive, (you can't put 100 GB of data into a 50 GB partition). Once the partitions are setup, use a cloning program to send desired data 'copy' to newer location. That should work fine. Best of luck.
