I replaced the hard disk of my powerbook and installed the operating system. It boots fine, but from the moment I power it on, the fan starts immediately at high speed. I put back the old disk, same problem.
I think I may have damaged something during replacement, but I do not know what. I checked all connectors, they seem to be fine.
I did not remove the heat sink, because I do not have thermal paste to put it back, so I do not know if something under it might have been damaged. Could you please suggest what I should check?
After a lot of checks, I suspected the fan connector (four wires, red, black, yellow, white). I removed it and put it back and the fan was not working. Then I pushed deeper the black cable and fan started again at full speed. I pushed all the wires of this connector with a pin to make sure they are in contact. Fan still at full speed. Other than this, the laptop works ok. Please help!
[quote|tos070]I replaced the hard disk of my powerbook and installed the operating system. It boots fine, but from the moment I power it on, the fan starts immediately at high speed. I put back the old disk, same problem.
After a lot of checks, I suspected the fan connector (four wires, red, black, yellow, white). I removed it and put it back and the fan was not working. Then I pushed deeper the black cable and fan started again at full speed. I pushed all the wires of this connector with a pin to make sure they are in contact. Fan still at full speed. Other than this, the laptop works ok. Please help![/quote]
