17" Powerbook G4 3 beeps at startup and no display
Reply by Facundus
From what i can find it seems to be ram related, but i have tried known good stick and both slots. when i remove the ram completely i get one beep still no display. any known tricks to try without buying a new board. bad solder joint or something on the ram slot . i have not quite received ninja status but i am pretty good with a soldering iron
Did you try cleaning inside the slots with contact cleaner and a stiff toothbrush?
Reply reply by Facundus
no but i will take a shot at it - thanks for the tip
well i hit it pretty good 2 or 3 times with the old toothbrush with no luck still. it gives me 1 beep without the ram and 3 with the ram so it is bound to be sensing something is there. any other suggestions before it get ebayed?
1 beep - no ram detected
3 beeps - bad ram in slots
try some new ram, or just try 1 stick in alternating slots.
i have tried that and even picked up a stick of kingston pc2700 locally with no luck. will normal pc sodimm typically work ?
Reply reply by Adamc242
I have the same problem with my Powerbook G4 12 inch. I haven't touched the Ram for years. Not sure if there is any connection, but I just did a security update and this is the first time I have started it after the update.
Reply reply by glenhandy
Powering of a computer requires the Pram battery to activate the keep alive portion of the HD. When this happens it start and check the RAM of the computer,when the RAM fails your dead in the water and nothing will happen from there on. Get yourself a known good stick and try booting your computer.
Reply to: 17" Powerbook G4 3 beeps at startup and no display
