I'm dealing with a friend's G4 933MHz iBook (Tiger OS). During the boot process it either freezes or advances to the Apple Logo and "spinning wheel" screen and then goes to a blue screen.
I connected it to my laptop in Target Disk Mode and ran Disk Utility. The HD tested OK. I could add or retrieve files without a problem. I also booted into the mode where you see only the command line. I did a check disk and again, no problems.
I have zapped the PRAM and reset the PMU. The latter step helped bring it along a little.
It will not start up off DiskWarrior or a Tiger OS Install Disk. In both cases it eventually freezes or goes to blue screen.
I'm not too wild about undertaking the 50-plus steps for swapping a logic board, but I would if I knew that would fix it.
Thanks.
