You need to clean INSIDE the mackbook NOW - there's nothing between the keys and the guts of the computer but AIR! The sticky sugary mess will cause corrosion. NO POWER (pull the battery too) You can use electrical contact cleaner and and old tooth brush, followed up by the 99% alcohol to speed drying. Hopefully there's nothing UNDER the logic board but the only way to know is to remove it and check/clean the back.
N
