Thank you for your advice. I tried your procedures and found this: I removed the PRAM battery. I can boot the system if I 1) shut the computer down, 2) remove both the powercord and the power battery (even though it is a week one) 3) plug them in, then it will boot up. As expected I need to reset the clock or allow it to automatically reset. I hope this indicates that I do not have a logic board problem.
To unplug and re-plug the power with the PRAM installed does not work, but it does work without the PRAM installed! I need to remove the power completely, THEN also remove and re-attach the PRAM and then the power before it will boot, in that order.
Now, does the above mean I have a dead PRAM battery? I wonder about the PRAM battery -- I bought one from a qualified ebay seller who said it was a tested and good battery. I don't have the equipment to test it but I wish I knew whether it is good or not. Perhaps I can take it to a nearby Radio Shack to test it.
I can live with this operation for quite a while (without the PRAM so I can finally sew up the computer again) instead of paying for a new computer. Perhaps invest in a new power battery.
Thank you for taking the time to reply to my question. If you have further insight about the actions/non-actions of the PRAM I would appreciate it.
It still seems to me that by unplugging and re-plugging the power that there is a reset that is taking place that doesn't take place without it.
Roy
