Well, it sounds like you have 2 problems:
1) The computer's batter holds a weak charge, and only has a short lifespan.
2) Your PRAM Battery is dead. you can change this pretty easilly, and they cost $30-$60.
Many macs behave erradicly when their PRAM battery's get low.
or, you could check your PRAM battery, hook your leads up to a volt meter, and a good battery will measure between 3.2 and 3.6 Volts.
[quote|Chris Green]Well, it sounds like you have 2 problems:
or, you could check your PRAM battery, hook your leads up to a volt meter, and a good battery will measure between 3.2 and 3.6 Volts.[/quote]
