imac G5 Keeps shutting down?
Reply by ilovemymac
I have an imac G5 and it'll run for a while then just shutdown. I am very worried. What mighht my problem be?
Reply reply by holiver
Sounds like a possible heat problem assuming that you have your AC plugged in and are not running on battery which you did not specify.
Reply reply by emil
If you want to check your heat monitors (one could be going bad), get the FREE app, iStat, here at: http://www.versiontracker.com/dyn/morein...
My 17" G4 kept shutting down unexpectedly and when I used iStat, I saw the "heat" on one of the (5) heat monitors shoot up to some absurdly high heat just before the laptop shut down (actually, it seems it was doing a sleep, but whatever -- screen went dark.)
Try iStat, keep an eye on it for a bit and see if one of your heat monitors is erratic. When I found which monitor had failed, I googled instructions on how to fix it myself (just removed it entirely) and the 17" is working great now.
Reply reply by Rich
There was some power supply problems with imac g5.. faulty power supplies...lots of info here:
http://forums.macosxhints.com/archive/in...-44705.html
http://jimwarholic.com/2008/11/apple-imac-g5-power-supply-issues-and.php
What do you mean
"it'll run for a while then just shutdown."
Will it run for a few minutes, a few hours, a few days? What are you doing when it shuts down?
Other solutions could be: "secured virtual memory" problem'' (uncheck it)''
Not enough free space on the HD
FileVault acting up
Reply to: imac G5 Keeps shutting down?
