If it's a software issue, boot the ibook holding down the COMMAND and the S keys until you see a black screen with white text then type:
fsck -f
This will check your system integrity and do the repairs if needed.
At the end of the processus a message should tell:
<<The volume (name of the hard drive) appears to be OK>>
If you have an other message redo the fsck -f action again.
When the repair is done type:
reboot
and press on the RETURN key.
If the problem is a failing hard drive this procedure will be no help. If so you should find a way to boot the ibook from an external source (firewire hard drive or firewire optical drive)to check the internal drive with Disk Utility.
[quote|lemerise]If it's a software issue, boot the ibook holding down the COMMAND and the S keys until you see a black screen with white text then type:
fsck -f
reboot
If the problem is a failing hard drive this procedure will be no help. If so you should find a way to boot the ibook from an external source (firewire hard drive or firewire optical drive)to check the internal drive with Disk Utility.[/quote]
