Bryandd
Flag Reply by Bryandd Nov 1 @ 4:10 PM
Hi
firstly thank's to QE2 for the help
i have a Mac I Book G4 it has only been used to webcam with my son who lives in the USA i am in the UK but yeasterday i got a message on it telling me there where upgrades available for I Tunes so i downloaded them, on completion the I Book shut gown so the uogrades where working thats when my problem arose it will now not reboot it sits there with the Apple logo aand the spinning ball and nothing else. has anyone had this problem anyone any idea how to get it to reboot
thank you in advance Bryan
Flag Reply reply by Skippy722 Nov 1 @ 5:57 PM
your harddrive might be going bad, do you have the restore disks that should have came with the computer?
Flag Reply reply by Bryandd Nov 2 @ 7:14 AM
Quote from Skippy722:
Hi Thank you for your reply
yes i have both disc's but i have tried them but still no joy and it is a struggle to geet the disc out again because all i get is the spinning fan and the apple logo i also saw that when close the i book it is not switching off
apple care tell me it is a software problem is this the same as you think ? i appreciate your comments Bryan
Flag Reply reply by QEII Student IT Nov 2 @ 10:00 AM
Hi Bryan
I've had this problem recently and if you look at the recent thread 'powerbook kernel panic' or along those lines that is the same too.
I am very suspicious considering your incident makes three of this kind I have heard of this week.
I was unable to fix mine. You cannot use holding t at start-up to connect via firewire to another cmputer. It is very odd and I find it very dodgy that these occurances are so close together on similar computers.
As for stuck discs just hold down the click as you start-up.
Sorry I can't be more help but I hope more about it is uncovered soon
Flag Reply reply by Skippy722 Nov 2 @ 4:05 PM
try replacing the harddrive and if that doesn't work your logic boardmight e bad...
Flag Reply reply by lemerise Nov 3 @ 8:53 AM
If it's a software issue, boot the ibook holding down the COMMAND and the S keys until you see a black screen with white text then type:
fsck -f
This will check your system integrity and do the repairs if needed.
At the end of the processus a message should tell:
<<The volume (name of the hard drive) appears to be OK>>
If you have an other message redo the fsck -f action again.
When the repair is done type:
reboot
and press on the RETURN key.
If the problem is a failing hard drive this procedure will be no help. If so you should find a way to boot the ibook from an external source (firewire hard drive or firewire optical drive)to check the internal drive with Disk Utility.
Flag Reply reply by QEII Student IT Nov 3 @ 10:53 AM
lemerise is correct but it is fsck -fy you should type not fsck -f
It this works great but it didn't with my iBook G4.
Flag Reply reply by Bryandd Nov 4 @ 4:12 AM
Quote from lemerise:
fsck -f
reboot
Flag Reply reply by Bryandd Nov 4 @ 4:20 AM
many thank's for this info especially to lemerise and QE11 it worked fine
Bryan
Flag Reply reply by Bryandd Nov 9 @ 12:44 PM
Quote from Bryandd:
Hi to lemerise you gave me some advise a few days ago about my ibook G4 and it seemed to work ok i was able to boot it up, and thought it was ok BUT
if i can expalin why i have a Mac it was bought for me by my son who lives in the states and it is used more or less just for web-cam sessions, i have some music and some photo's on it as well
after doing what you advised i was able to boot it up, but could not open any of the proga on it ie ipic's or ichat as it was not long out of warranty i rang apple care they said as it was a software prob they would look at it theey checked everything out said it was working fine and went through the reinstall software process but my son installed it all about 4 years ago and cannot remember what he used as the password we have gone through it over the past week all to no avail trying to get back to the original settings do you know any way to find out the original password
Bryan
Flag Reply reply by lemerise Nov 9 @ 1:31 PM
You can reset the system password if you still have the ibook original install disk or with a retail installation disk. Just boot the ibook with the installation disk holding the C key when you ear the chime until you see the grey screen with the apple. Once the system disk is loaded, choose a language and on the next screen go to the Utilities menu and choose the Reset Password sub menu, write the new password for the ibook volume and that's it. Exit the installation procedure and restart choosing your ibook HD.
Flag Reply reply by Bryandd Nov 9 @ 2:00 PM
Hi
i have all the original disc's i also have the ilife disc
i tried the reset password procedure and it seemed ok but when i tried to reinstaall i got a messagee telling me it needed 2.8g to reinstall and there was only 1.8 free space left i had given up trying to get back to original settings and devcided to wipe everything
as u probly gathered i do not know a lot but i can get by with the right advice so i shall try again with what you have said
mnay thanks Bryan
Flag Reply reply by lemerise Nov 10 @ 3:48 PM
No problem whiping the disk and doing a clean install. That's the better way to install a fresh system but you need a back up of your data before doing it.
Flag Reply reply by Bryandd Nov 11 @ 2:00 AM
thank you for that but i lost all interest in what data i had my son says he has all that matters so i just wiped it and installed a new system, i managed that but when i tried to reintall some data it tells me "" no default application to open the document "" sorry to ask but what do i do now, as i said i do not know much but can follow instructions
Bryan
Reply to: Bryandd
