Next »Page 1 of 2
Help...replaced HD in Macbook Pro core duo, and now no internal Hd shows in Disk utility
Reply by jreuben65
I connected all the cables...i can hear and feel it spinning, but when i boot up with my external boot drive...i can't see the new drive in disk utility to format it...
it is a seagate 7200rpm 320gb
i hooked up my old hd and the same thing...i can hear it spin, but it is not in the disk utility sidebar...and it is formatted already.
any clues..
thanks for any help, I am really frustrated
Reply reply by Skippy722
maybe you damaged the cable that carries the data?
Reply reply by jreuben65
its the same cable as power...seems like i barely touched it, but that seems to be the only answer...though I keep thinking there is some issue that just is preventing it from seeing the HD bay..it must be the cable...anyone have a similar experience? Power, but no data?
this is the cable I am talkng about
http://www.ifixit.com/MacBook-Parts/MacBook-Pro-15-Inch-Core-Duo-Hard-Drive-Cable/IF185-030
the light works the IR, the power to the drive...only data seems to be not there...is this possible?
Reply reply by Randee
Hi, I would suggest booting on Knoppix (or similar), http://knopper.net/, there is lots of information online regarding HFS and Knoppix/Linux.
I am not experienced with MacBooks but know there is a BIOS like utility that may be the best starting place to see if the drives show up before you start replacing expensive cables.
There are many bootable CD images available that may help you also.
what model is your MacBook and whatkind andhow big (in gigabytes) was the old harddrive?
its the early MBP, 2.0ghz core duo (not core 2 duo)
it had a fujitsu 80gb 5400rpm HD
I am replacing it with a Seagate 320gb 720rpm HD
I am running Snow leopard...
I cloned the old Hd and am booting from a 1tb external Maxtor
I have reset P vram
I have unsucessfully tried to run a hardware check at startup
No Serial AtA shows up in system profiler like the old fujitsu did
I tried connecting the new drive before closing the lid...it didn't show..i reconnected the old drive, it didn't show either (i have wiped it and it is no longer the boot drive)
it ir works...the sleep light works, but maybe not the same as before (i can't remember if it stays on while the computer is on, it isn't now), but does come on when sleeping.
i am at wits end...
maybe the new drive has too many gb's and thus can't be recognized by the computer?
Reply reply by paolo29
1TB 2.5
ide to sata are thay available yet
wait, you said that you booted with an external drive? if so, did you remeber to switch the boot drive back to the internal?
Skippy, what do you mean switch back? I have concluded its the data part of the ribbon cable and have another on order...but open to more suggestions
when you boot from a different drive you have to choose tht drive right? if so, you may have to select the internal drive for it to be used
Reply reply by Chris Green
Try putting the drive in a different computer with an os and drive already on it. if it doesn't show up in disk utility, than the drive is most likely dead.
Reply reply by valid
First thing to do: put the drive in an external 2.5" enclosure (USB or Firewire) and see if it is seen by the system on this mac booted from your other external boot drive.
It should say that there is a new disk. Do you want to initialyse it?
Then disk utility will pop up.
@valid...I have done that...both the new drive and the old drive are fine in the enclosure...i can see them, format them, partition them etc...
but while i can hear and feel the drives spinning when in the internal drive bay, neither is recognized in any fashion...(they are both now formatted correctly and like I said, work fine when in the external enclosure...
I am hoping that the new ribbon cable will fix this...i will let you all know when it arrives..
thanks for all the advice and attention to my problem.
Reply reply by moldor
Just a thought - check the connector on the drive to see if there are any bent pins. I had this happen on an old laptop where it wouldn't recognise a brand new drive. Turns out I had dislodged a pin which wasn't actually in the connector. Straightened that out, reconnected the cable and all worked fine.
Another thought - did you change the jumpers on the new drive at all ? I believe they have to be set to MASTER or CABLE SELECT (use MASTER when in doubt).
Reply reply by customerservice
You need to format the hard drive before your Mac will recognize it. You can get a unit that will help you with this at most electronic supply stores. That's why it doesn't find it.
@customerservice....it doesn't recognized formatted disks in the internal HD bay either...I have formatted my new drive and it is still invisible in disk utility..
@moldor- how do you change the settings on the cable...i don't see anyway to do that.
Sorry - not on the CABLE, but on the DRIVE - there should be a set of jumpers on the back of the drive near the connector.
Quote from customerservice:
Rubbish - as soon as you plug it in the Mac will recognise it - it may not *read* or *write* to ir without formatting using Disk Utility, but it will *see* the drive.
http://www.helpwithpcs.com/upgrading/ins...-hard-drive-ide/installing-hard-drive-fig-1-2.jpg
that's what moldor is talking about if your still lost, check and see if it's set to master like moldor said
                   Next »Page 1 of 2
Reply to: Help...replaced HD in Macbook Pro core duo, and now no internal Hd shows in Disk utility
