When I put my iPhone 3G on silent and there is a bit of pressure on the button or front top left of the phone (even as little as the pants when I am walking) the phone will turn on and off silent mode. Is there a simple way to fix this?
CMac Oct 3 @ 11:42 AM
I have the same problem and it has just been getting worse, now it doesn't even go to silent!
EdithC Oct 27 @ 11:30 AM
I have the same problem. My won't go to silent anymore either.
James Oct 30 @ 11:45 AM
had this problem, sent to apple. they wanted £157 to repair!
I took the phone apart myself and found a screw loose inside!
Once I put the phone back together all was fine.
HOPE THIS HELPS!!!
catroga Nov 6 @ 8:58 AM
Same problem here. Is there a tutorial somewhere?
gochga Nov 10 @ 6:37 AM
Your iPhone has a loose connector plug that attaches the ringer mute switch to the logic board. To repair it requires that you disassemble the iPhone down to the plug. This will mean that you have to open the iPhone and take out most of the components.
Hardest part is to remove the battery due to the adhesive backing. To avoid damaging the case, use a suction cup to pull off the display touch screen glass (after removing the two screws holding the case together. Just follow the tear apart instructions for the iPhone.
Reseating the connector will usually fix this problem.
