I understand what terminal is/does, but I've only used it once before and don't know anything about forming the commands.
I do have a firewire cable, my other computer is an iMac Intel Duo.
I don't have access to any non-Intel Macs
I thought I'd try installing the OS without reformatting the disk because I wasn't sure the reformat was necessary (and terminal scares me).
I entered the commands again, but I was paying more attention to the response this time.
I believe the issue may be with the front end of that command.
If I enter:
/Applications/Installer.app/Contents/MacOS/Installer /System/Installation/Packages/OSInstall.mpkg
I get the message:
-bash: /Applications/Installer.app/Contents/MacOS/Installer: No such file or directory.
Since I don't know squat about "Terminal", and had nothing to lose, I figured I'd give the reformatting a shot anyway.
The reformat went fine until the end.
When I entered:
diskutil eraseDisk JHFS+ iBookHD APMFormat disk0
I got the response:
Started erase on disk disk0
Creating Partition Map
Could not unmount disk for zeroing
Partitioning encountered error Could not unmount disk (-10000) on disk0
This is why terminal scares me, I think I killed something.
I went back to the Disk Utility and selected restore using the install disk as a source and the untitled folder on the HD as a destination.
It appears to be copying the Install disk onto the HD, but I have no idea what will come of that.
Thanks
M
[quote|marcucco]I understand what terminal is/does, but I've only used it once before and don't know anything about forming the commands.
If I enter:
I get the message:
When I entered:
I got the response:
Thanks
M[/quote]
