iBook G4 1.2 w/ a white screen, not the solder issue.
Reply by marcucco
I poked thru all 25 pages of the BB and didn't find a solution so I thought I'd give posting a shot.
The iBook's LCD boots up to pale gray/ white screen with no image at all,
the backlight does come on, it dips when it goes to sleep or an external monitor is attached.
The computer runs perfectly on an external monitor.
The screen is not black, the fan does not run-on, putting pressure on the "video chip" has no effect.
This started out of nowhere. It worked fine one day and was dead the next, no bumps or bangs or errant beverages.
Hardware things I tried:
-replacing the LCD
-replacing the LCD ribbon cable
-replacing the LCD inverter
-replacing the LCD inverter cable
-remove the memory chip
Inspections:
-The solder joints on the ISL 6225CA chip look fine.
-The jacks on the logic board for the LCD and the LCD inverter appear to be good.
-No bulged or discolored chips.
Software stuff:
-Apple Hardware Test disk found no problems.
-TechTool found no problems.
-Repairing permissions, zapping the Pram, NVram and all the stock software pimp-slaps didn't help.
-Starting in "Target Mode" leaves me with a black screen, no backlight.
- (it does show the Firewire logo on a blue screen if I plug in the external monitor)
-The F1 & F2 buttons have no effect on the appearance.
-It really felt like a software issue so I did a "Clean Install", no help.
Anybody got any ideas?
Reply reply by somecrazylady
Sure sounds like a video data problem, getting backlight but no data. I would have guessed the lcd ribbon data cable. If that didn't fix it I would think the chip is bad and not just the solder. You certainly have tried everything else I could think of.
Reply reply by marcucco
Thanks.
Gotta be the Logic Board. one of those bits that connects to the screen but not the external monitor bit the dust I guess.
Reply to: iBook G4 1.2 w/ a white screen, not the solder issue.
