I have a 15", 1.67 lo-res model in excellent shape with a strange issue. It will run perfectly, forever, if I don't try to reboot, shut it down, or put it to sleep. If it's been on for over an hour and I try to do any of those things it will show a dark screen but you can see the desktop very faintly.
If I let it sit for about 45 minutes it fires back up and the display is fine.
By looking through the repair section here on ifixit, the dark screen is caused by the inverter, complete display or logic board. The problem seems to be heat related as it happens once it gets hot and then goes away once it cools down.
Do these symptoms point definitively to any one area? I don't want to start replacing parts until I know exactly what the problem is.
Thanks ahead of time for any help.
[quote|oc63rag]I have a 15", 1.67 lo-res model in excellent shape with a strange issue. It will run perfectly, forever, if I don't try to reboot, shut it down, or put it to sleep. If it's been on for over an hour and I try to do any of those things it will show a dark screen but you can see the desktop very faintly.
Thanks ahead of time for any help.[/quote]
