iPhone 3G Home Button doesn't work.
Reply by sycomonkeys
I just replaced the digitizer, the glass screen, on my iphone and the Home button now doesn't work... any ideas?
Reply reply by cmoazz
When I did this, I noticed that I accidentally unplugged cable #4 inside. That fixed it for me.
Reply reply by Raymacdk
Hi. If you used a heater to warm the glass, you might have overheated the button. It only shows on the back where it can be bended a bit by the warmth. u can then lift of the cable and use a piece of sanding paper to flatten the buttom of the button :-) Then replace the cable and you should be good to go.
Reply reply by sycomonkeys
I figured it out screen was sitting perfectly flat cause of a screw (I also had to replace the dock assembly) wasn't screwed down all the way
Reply reply by luisfelipe3054
hi!! i just change the home back case and the iphone turns on but now the home button doesnt work!! any ideas?? thanxx
Reply reply by JON MO
After you replace everything and the Home Button still doesn't work then try this: put cardboard slide it under copper connecter ribbon and also on the back of your home button and secure with scotch tape then try it out. This should give the home button support for when you push down on it.
Reply to: iPhone 3G Home Button doesn't work.
