it sounds to me that either the battery is dead on your iphone or one of the battery wires may have come lose from the motherboard,
The only way to check these things is to open the iphone up. Have a tech open it and first check if it has been water damaged. If it has been water damages, check the voltage on the battery. With a volt meter you should get 4.20 volts or higher.
If the battery is very low while the iphone is open, plug the charge in and test the voltage with it plugged in. It should vary from without the charger in. If not difference it could be the charging port, chean with a brush, if there is green electrolysis in the charging port you can use vinegar to clean it, if your going to clean with a liquid, it's best to remover the motherboard so the charging port is not hot. The symptoms your iphone exhibits could be many different things. check what you can and have a tech test the rest.
[quote|ipodslinger]it sounds to me that either the battery is dead on your iphone or one of the battery wires may have come lose from the motherboard,
If the battery is very low while the iphone is open, plug the charge in and test the voltage with it plugged in. It should vary from without the charger in. If not difference it could be the charging port, chean with a brush, if there is green electrolysis in the charging port you can use vinegar to clean it, if your going to clean with a liquid, it's best to remover the motherboard so the charging port is not hot. The symptoms your iphone exhibits could be many different things. check what you can and have a tech test the rest.[/quote]
