First question... Let me say something... almost everything Apple runs HOT. If you ever get the opportunity to see an Apple TV unit, you'd think it would start a fire at normal operating temperature. So... if your MacBook isn't experiencing shutdown and the fan noise isn't too bothersome, I wouldn't keep messing with it personally. There are several (not just one) sensors inside your MacBook that adjust the fan speeds according to need and keep the internal temperature in check.
In reply to the PC DOS question... first of all, a CMOS stands for Complimentary Metal Oxide Semiconductor, and electronic part, like a transistor is. So I don't quite understand how that would work. That's getting into an area where, in my professional opinion, one shouldn't.
As for Time Machine... I'm sure you already know it will restore your computer files and applications as they were at a previous point in time. ...Almost. For more particulars on Time machine, a great place to learn is www.apple.com/support where you can get answers straight from the horses mouth as to what Time Machine will and will not restore.
In closing, I just want to say that I speak with folks almost daily that are worried nearly to a frazzle because their Macs are running so hot. But believe me, if your MacBook is in any danger, it will shut down on its own. If that's not happening, in my personal and professional opinion, I would just start enjoying the MacBook. One can get to a point where there is too much concern over too little. But... Should all else fail to satisfaction, there's always the option of using your original OSX disc and doing a Repair or, in worst case, back up your files and applications and re-install OSX. Seriously though... the "green" hard drives really do cut the heat. Mine is a Seagate "Momentum". Good luck!
[quote|customerservice]First question... Let me say something... almost everything Apple runs HOT. If you ever get the opportunity to see an Apple TV unit, you'd think it would start a fire at normal operating temperature. So... if your MacBook isn't experiencing shutdown and the fan noise isn't too bothersome, I wouldn't keep messing with it personally. There are several (not just one) sensors inside your MacBook that adjust the fan speeds according to need and keep the internal temperature in check.
In closing, I just want to say that I speak with folks almost daily that are worried nearly to a frazzle because their Macs are running so hot. But believe me, if your MacBook is in any danger, it will shut down on its own. If that's not happening, in my personal and professional opinion, I would just start enjoying the MacBook. One can get to a point where there is too much concern over too little. But... Should all else fail to satisfaction, there's always the option of using your original OSX disc and doing a Repair or, in worst case, back up your files and applications and re-install OSX. Seriously though... the "green" hard drives really do cut the heat. Mine is a Seagate "Momentum". Good luck![/quote]
