Object stuck in audio port, macbook
Reply by mffthng
Recently while connecting external speakers to my macbook, the top of the jack plug of my speakers broke off. It's stuck inside my audio port and there is no way to get it out. Because it is stuck in there my macbook thinks there is an external audio output (speakers, headphones) connected, and therefor it blocks my macbook speakers from working. And since there is nothing connected, just the tip of a jack stuck in there, I am left with no sound on my macbook.
I thought about trying to open up my macbook but then again I think the audio ports are closed so I couldn't just push the thing out from inside. (are they?)
Also people have suggested to super glue something against it and pull it out, but there is no way that the glue will be strong enough for it to be pulled out. Some people suggested using a magnet but I'm afraid that might do damage to my computer. The hole is also too narrow for tweezers or anything like that to pull it out.
I found a few threads on the internet discussing this problem but none seemed to give an actual solution or anyone that successfully resolved this problem.
Does anyone have any other suggestions that might help? I'd rather fix it myself than to send my computer off to apple and pay the repair costs. (I don't expect them to be cheap.. :S)
Thanks
muffthang@gmail.com
Reply reply by draco07
Don't hold me to this, but you might have to take the logic board out of the laptop, and see if it would fall out of the laptop that way. Is it genuinely stuck fast inside the audio jack itself, or is it just inside the audio jack and stuck behind the laptop's outer chassis? I strongly advise against using superglue, chances are that that will make your removal tool get stuck inside the audio jack; or, the glue will leak on physical contact and literally seal the jack inside the MacBook. If you know how to take out the logic board, try that and see if it will fall out on it's own.
Reply reply by mffthng
It's genuinely stuck. Jacks are designed to click and stay inside the audio port so it doesn't just fall out when you tilt your computer side wards. Thus it is really stuck in there. Another suggestion? What do you think apple would do to fix this if I bring it in?
There is no reliable way to take off the broken jack plug from the sound port. If you look closely at a jack plug you'll notice that the plug has 3 sections. Most of the time the end of the plug (first section) is broken and stuck in the bottom of the port. The sound port has two metal tabs inside that make contact with the jack plug sections two and three and these two tabs are making obstuction when you try to pull the broken part out of the port. I think the only way to repair is to take off the motherboard from the machine and pay a tech to replace the whole port with a working one.
I have removed many broken jacks from audio ports using super glue. If you get the right amount of glue on the end of the broken jack and leave it in so it can set properly it will come out. Don't use too much or you'll glue yourself into the jack. Use a small amount and let it set for half an hour or so and it should pull right out. Done it at least 30 times personally.
Reply reply by BertN
Superglue is not a bad idea, but a little risky.
The one time I had the same problem, I drilled with a 1 millimeter drill a bit in the stuck part, not too much. (Battery and power cord out - of cause.)
Then I used superglue on the used drill, made it stick with the hole in the broken bit, waited the half hour - and pulled the bit safely out.
/bert
Excellent idea. I may see how that works next time I get one in.
Reply reply by Cinders
Did you solve the problem ? I have the exact same issue and it would help to know what you did. Thanks!
Reply to: Object stuck in audio port, macbook
