G4 iBook Hard Drive Replacement
Flag Reply by jbehaylo Jun 19 @ 6:35 AM
Hi All,
I followed the iFixit guide to upgrade the hard drive in my 12" 800 mHz G4 iBook (http://www.ifixit.com/Guide/Repair/iBook-G4-12-Inch-800-MHz-1-2-GHz-Hard-Drive-Replacement/166/1). Felt pretty confident about having followed instructions to the letter (no guessing about replacing screws, no forcing to close it back up, etc.).
When I rebooted, optical drive and hard drive seemed to be making all the rights sounds, but nothing came up on the screen. The new HD needed to be formatted and the OS installed, but I expected to see some sort of prompt. Am I right about that, or did I need to start with an OS install DVD in the optical drive? I don't believe there was any step in the upgrade process where I was messing with the display connector. Any ideas?
Next try was to reboot with the OS install DVD in the optical drive. But I was physically unable to insert the disc into the slot. The center area had an obstruction, although the sides seemed clear. The optical drive was empty when I started the disassembly. I think the center spindle, head or whatever it is called may be locked as if there were a disc inserted. Does that sound right, or might the whole mechanism not be fitted properly from the reassembly? I didn't need to remove the optical drive to do the HD replacement, and don't recall that any screws I removed/replaced were holding the optical drive. Also don't recall disconnecting it as part of the instructions. Any ideas?
Thanks for any advice (besides not trying to do this at home or letting a certified Mac tech do the job next time ;-)).
Joe
Flag Reply reply by marcucco Sep 16 @ 8:12 AM
Check that the 3 screws to the right of the case under the keypad are the proper length, they should be shorter then the others. Using the wrong (too long) screws can distort the disk drive.
Flag Reply reply by jbehaylo Sep 17 @ 9:14 AM
Thanks for your reply. I forgot to update that I did get the iBook running. Turns out I had left a DVD in the drive and so was unable to insert the OSX install disk.
The iBook has now been running a few months with the new hard drive, maxed-out ram (1.25gB) and OSX 10.5 very smoothly. (I did the hack work-around for 10.5's minimum requirements.)
Reply to: G4 iBook Hard Drive Replacement
