iphone 3g speaker not working.
Reply by persol
After replacing my front screen using the ifixit directions, my ear speaker is not working. I hear using speaker phone but for some reason the regular speaker does not work. I believe the ribbon might not be inserted into the slot all the way however I have no way to tell and it does not want to go in any further although some gold connection is still showing.
Any advice would be great.
thanks
Reply reply by Brady Cabe
Take a look at Step 6 on our iPhone 3G front panel guide. This ribbon can be tricky and may require disconnecting and reseating to make sure the connection is good. Try to match the picture in Step 6 the best you can and that should solve your issue.
Reply reply by persol
Thank you, I will go ahead and give that a try.
Reply reply by peterweyns
The same with my iPhone. It works fine, only my ear speaker is not working.
Reply reply by Rah Dikkha dwn
Is there a way to solve this issue
Quote from persol:
did it work????
Reply reply by plymouth54
I have the exact same problem after replacing the rear back panel casing. Well I triple checked that ribbon #3 is firmly connected. Any ideas?
Reply reply by Dinowarrior18
Ill give it a try but any other advice is appreciated.
Reply reply by slwalters3123
Funny. Same thing from me. Just replace battery and front screen and ... when I talk on phone, I can barely hear a sound.
Reply reply by Luciilliia91
I Had The Same Problem .. When i Got into My Phone to Check The Problem, i found The Plastic Covering The Slot Had Snapped Off .. This Means it Wont Stay And i Cant Slot My Ribbon in .. i Think i May Have to Get a Brand new One x
Reply reply by Eric Gentry
when i am on my speakeron my 3G phone, the person i am speaking with cannot hear me.
Any ideas?
Reply reply by Rodrigo Lobato
Does anyone know how to fix it?
Reply reply by Fred K
Is this resolved at all? Does anyone have an idea why this is happening?
Reply reply by Arpu
My iPhone 3g speaker's stopped working one day. Not sure if need to replace the speakers and how? I can talk and listen to music and everything if I use headsets.
I can talk to ppl without using headsets too but not on speakers. I don't get any ringtones, songs or any other sound ewithout headsets. Any help?
Reply reply by Jennie
I am currently having the same problem and have done all the above suggestions. I unplugged and replugged...it doesn't go all the way in...only about half way...is that a problem? I have plugged and unplugged headphones several times too and that isn't working! suggestions?
Reply to: iphone 3g speaker not working.
