Broken ipod touch 2nd gen
Reply by DETpistons3
Hey guys I need some help fixing a 16gb iPod Touch 2G. I bought it broken from a friend who had let his friend borrow it. I figured I’d be able to fix it. When I received it, it wouldn’t turn on at all. I plugged it into the computer and did a hard restart, and it turned on to a white screen with vertical lines flashing randomly. The computer recongnized it and everything that was on the ipod appeared on itunes. I then used itunes to reset the ipod to factory settings. The reset worked perfectly in itunes but, the ipod touch was never able to boot up. I’ve put the ipod into dfu mode and used Quickfreedom to jailbreak the ipod just to see what would happen. The jailbreak worked, but once again, the ipod was unable to boot up. Help would be greatly appreciated. Here are some more details:
• 16gb ipod touch 2nd Generation
• Some dings and multiple scratch on back
• I’m able to slightly push down the bottom of the screen
• No apparent water damage (sensor in headphone jack is white)
• When I move a magnet over the home button, the white screen w/ lines reappears.
• Won’t fully boot up (stuck on boot screen)
• Very faint white dots on the bottom of the screen
• Gets the bottom of the ipod heats up significantly more than the upper half.
• THE COMPUTER RECOGNISES THE IPOD (Computer treats the ipod like a perfectly working ipod).
• While restoring the ipod through itunes, the ipod makes a very high pitch noise, only able to be heard when put up to ear.
If you need any further information about the ipod, or have any suggestions, email me at kribsrobby@yahoo.com.
Thank you very much for taking the time to read this.
Reply reply by Chris Green
Looks like a bad screen, of or a bad ground connection, and it's never a good idea to put magnets on electronics, they can wipe out flash memory easily, and can brick the device.
Reply reply by Claus Pieppiep
Wrong.
Magnets won't affect flash at all, it can though mess up harddrives and also the touch screen and accelerometer will produce (almost) random data, but it shouldn't hurt anything.
the beep noise could come from a chip or a condensator which is slightly overused, so maybe that's why the iPod doesn't get to boot b/c it just cannot power the processor enough (just a guess)
also it could be that the firmware or boot-process is interrupted at some point, i don't really know if itunes restores that too.
but what i think is that someone sat on the screen or broke it somehow which may also have damaged some parts.
what you can try is opening it up and look for burned/extremely hot/cracked parts
Reply to: Broken ipod touch 2nd gen
