Quote from king2440:
Thanks I will check it out
Thanks for the Posting as for the Docking Station that you are Using their is your #1 Problem!!! As for Docking Stations, Car Chargers, and FM Transmittors I have seen a lot of iPODs come through the Shop with Sound Problems. Main problem no sound out of Both Ear Pieces? The Problem the Amps Mico Processor on the Logic Board is Blown. Have you ever went to a Rock Concert and they Have their Sound turned up so much and all of a Sudden their Amp Shuts off or over Blows the Circuit resulting needing a New Amp? Well in your Situation it is your Logic Boards Amp on the Board which is called the Sound Processor. By Cracking the Volume up on the iHome your iPOD cannot handle it and it has Blown your Amp on your Board.
MEANING:::Logic Board Replacement?
Check to see if ifixit.com has a 30gb Photo Logic Board if not you are welcomed to Purchase from us and have this Repaired by ifixit.com or by us Affordable E-Tech Repair Parts.
Kind Regards
Also the Logic Board and Hard Drives for iPODs are the Most Costly to fix without these your iPOD will not Run!!
[quote|RepairTech1]Thanks for the Posting as for the Docking Station that you are Using their is your #1 Problem!!! As for Docking Stations, Car Chargers, and FM Transmittors I have seen a lot of iPODs come through the Shop with Sound Problems. Main problem no sound out of Both Ear Pieces? The Problem the Amps Mico Processor on the Logic Board is Blown. Have you ever went to a Rock Concert and they Have their Sound turned up so much and all of a Sudden their Amp Shuts off or over Blows the Circuit resulting needing a New Amp? Well in your Situation it is your Logic Boards Amp on the Board which is called the Sound Processor. By Cracking the Volume up on the iHome your iPOD cannot handle it and it has Blown your Amp on your Board.
Kind Regards
Also the Logic Board and Hard Drives for iPODs are the Most Costly to fix without these your iPOD will not Run!![/quote]
