The Sleep switch is in the lower left area.. - You can open the unit an remove it.. see if the computer runs normally without it..
http://www.ifixit.com/Guide/Repair/MacBo...-Core-Duo-Battery-Connector/293/1
Step 13 shows the battery connector.. which is also the sleep / read switch for the macbook..
computer will run without it.. just wont be able to run off battery or sleep when closed.
[quote|matthewfrey]The Sleep switch is in the lower left area.. - You can open the unit an remove it.. see if the computer runs normally without it..
http://www.ifixit.com/Guide/Repair/MacBook-Core-Duo-Battery-Connector/293/1
computer will run without it.. just wont be able to run off battery or sleep when closed.[/quote]
