It's possible, but it's an arduous process. The upper case is the part that most things are screwed into, so you must remove almost everything from the laptop. Then there are nearly 50 tiny screws that hold the keyboard in place. It's not impossible, but it may not be worth your time.
[quote|Ben Eisenman]It's possible, but it's an arduous process. The upper case is the part that most things are screwed into, so you must remove almost everything from the laptop. Then there are nearly 50 tiny screws that hold the keyboard in place. It's not impossible, but it may not be worth your time.[/quote]
