Battery
1 Answer 2 Score |
Power button not turning on |
1 Answer 0 Score |
Can I upgrade ram on this device is it possible? |
1 Answer 0 Score |
How do I add a ssd into it? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you already know your problem and think it is a frequently asked one, consider looking at our troubleshooting page.
Background and Identification
The Toshiba Satellite CL15t-B1204X is a small, silver, entry level laptop. It is 0.8" thick with an 11.6" screen. The laptop comes with Windows 10 Home pre-installed. In terms of hardware, it has the dual core, 2.16gHz Intel celeron N2840 cpu installed, as well as 2gb of DDR3L RAM, and a 32gb ssd under the hood. The 11.6" touchscreen display a resolution of 1366x768. In terms of networking, it has an 802.11b/g/n Network Interface Card as well as Bluetooth 4.0 built in. This laptop has a USB 3.0 port, a USB 2.0 port, an hdmi port, an sd card reader, and a 3.5mm headphone/microphone combo jack. All of this is powered by a 29WHr battery which should keep this laptop up and running all day.
The Satellite cl15t-b1204x has a sticker on the bottom with a model number and serial number which can be used for identification.
