Ask a Question Support Questions
| 1 Answer 0 Score | Wont turn on, contact issue? |
| 5 Answers 0 Score | Gopro front lcd screen |
| 1 Answer 0 Score | Charging and power problem |
| 1 Answer 0 Score | got wet can it be repaired? |
Tools
Common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification ¶
The HD Hero 2 was released in October of 2011. GoPro claims the Hero 2 to be "Twice as powerful in every way" when compared to the original GoPro Hero. It sports an 11 MP sensor, 2x faster image processor, 2x sharper glass lens, and ten 11MP photos per second burst, among other improvements. The Hero 2 is designed to be wearable and gear mountable, waterproof to 197 ft (60m), and capable of capturing professional full 170º wide angle 1080p video and 11 megapixel photos at a rate of 10 photos per second.
To check that your device is, in fact, the HD Hero 2, check to make sure it says "Hero 2," as opposed to "Hero," under the lens.
Tech Specs ¶
Camera Optics
- 2x Sharper Professional Glass Lens
- f/2.8 Fixed Focus
- 170º Wide FOV (Including 1080p)
- 127º Medium FOV (In 1080p)
- 90º Narrow FOV
Video
- HD Resolutions:
- 1080p: 1920×1080, 30FPS
- 960p: 1280×960, 48FPS + 30FPS
- 720p: 1280×720, 60FPS + 30FPS
- Standard Definition Resolutions
- WVGA: 848×480, 120FPS + 60FPS
- High Performance,1 /2.3” CMOS Image Sensor
- Light Sensitivity: .84 V/lux-sec
- Video Format: H.264 codec, .mp4 File Format
- Exposure Control: Spot, Center Weighted
- White Balance: Auto
- Resolutions: 11MP, 8MP, 5 MP
- FOV: Wide 170º FOV, Medium 127º FOV
- Capture Modes: Single, 10 Photo Burst, Time-Lapse*, Self-Timer
Audio
- Mono, 48 kHz, AAC Compression, Auto Gain Control
- Stereo External Microphone Input (3.5mm)
Storage
- Memory:
- SDHC: Up to 32GB (Class 4 or Higher)
- Average Response Time With 32GB SD Card:
- 1080p30: 4 hours
- 960p30: 6 hours
- 720p60: 4 hours
- 720p30: 6 hours
- WVGA 120: 4.5 hours
Battery & Charging
- 1100mah Rechargeable Lithium-Ion
- Charge via USB
Operating System
- Microsoft Windows® Vista, 7 and Later
- Mac OS® x 10.5 and Later
