5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.773752
Background
The Craftsman Trimmer 917.773752 is a gas-powered string trimmer. The trimmer is equipped with a 22-inch cutting width and is powered by a 6.75 HP four-stroke engine. The engine is fueled by unleaded regular gasoline with a capacity of 1.25 quarts. This trimmer utilizes an oil type of SAE 30 above 32°F and SAE 5W-30 below 32°F with a capacity of 20 oz. The trimmer line has a diameter of 0.155 inches and a length of 18.75 inches.
Additional attributes of the trimmer include a folding upper handle for storage purposes, an adjustable assist handle and throttle control on the upper handle, and six different cutting height adjustments ranging from 1.5 - 3 inches. The trimmer also features an easily replaceable trimmer head drive belt and a metal debris shield. It weighs approximately 20 lbs. This particular model is a part of the 917 series of lawn and garden tools and was manufactured in the early 2000s. It is used for yard trimming duties.
Technical Specifications
- Model Number: 917.773752
- Product Type: Gas-Powered String Trimmer
- Engine: 6.75 HP four-stroke
- Fuel Type: Unleaded regular gasoline
- Fuel Capacity: 1.25 quarts
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Trimmer Line Diameter: 0.155 in
- Trimmer Line Length: 18.75 in
- Cutting Width: 22 in
- Weight: Approximately 20 lbs
- Handle: Folding upper handle for compact storage, adjustable assist handle and throttle control on upper handle
- Cutting Height Adjustments: Six adjustments from 1.5 - 3 in
- Additional Features: Metal debris shield
Warranty
The Craftsman Trimmer model 917.773752 comes with a two-year limited warranty. This warranty covers the trimmer under normal usage and does not extend to commercial use. To claim the warranty, it's likely that you will need to provide proof of purchase and may need to return the product to the manufacturer or an authorized service center. As specific instructions for claiming the warranty are not mentioned, it is recommended to consult the product's user manual or contact the manufacturer directly.
